Best ever barn find.This hood has no serious rust. Only surface rust in places. Lots of shiny original paint on the under side. Old faded paint on the outer side. Would be good for your old beater or an old faded restoration, requiring no work. It has dents on the top two panels but can't seem to make them show in the pictures. Someone borrowed one of the underside support strips, along one front edge, but could be easily replaced with a piece of thin steel and rivets using the undamaged original rivet holes.See picture number 2. This hood fits all T's up through 1916 but is correct for late1915 and 1916, as it has louvers and is steel. 1915 hoods were aluminum a good share of the year but steel in the later part of the calendar year. Does not fit the 1911 torpedo which has a longer hood. Best old original early hood I've ever found. Good candidate to restore.$70.00 Would make a nice stocking stuffer if your feet are really really big! Steve
Call with questions 810-664-1287
or email sgfmodelt@hotmail.com
For Sale 1915 1916 hood
sgfmodelt
Topic author - Posts: 39
- First Name: steve
- Last Name: farley
- * REQUIRED* Type and Year of Model Ts owned: 11 touring, 22 centerdoor, 23 touring, 24 coupe
Craig E. Luton
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Re: For Sale 1915 1916 hood
steel hood is 1916,not 15. 1915 hood is aluminum.
sgfmodelt
- First Name: steve
- Last Name: farley
Thank you, will correct. I read where it was steel starting somewhere in 15.
sgfmodelt
- First Name: steve
- Last Name: farley
back to top
