Wanted: 1926/1927 Wire Wheel Front Hub
Speedster Jeff
* REQUIRED* Type and Year of Model Ts owned: 1923 Model T Ford Speedster
Post by Speedster Jeff » Thu Jan 05, 2023 10:30 am
Hello,
I am in need of one (1) good front wire wheel hub for a 1926/1927 style wire wheel. One of the hubs I was rebuilding has a spun outer bearing and I would like to purchase a good used one that doesn't have this problem. After speaking with a few T folks, this seems to have been a problem.
Thank you,
Jeff Smith
Stuart, Florida
Re: Wanted: 1926/1927 Wire Wheel Front Hub
Post by speedytinc » Thu Jan 05, 2023 11:07 am
Loctite 660 gap filling, hi strength, bearing retaining compound. This stuff will fix your problem.
Post by Scott_Conger » Thu Jan 05, 2023 11:08 am
There are safe and durable ways to repair what you have. If you are intent on purchasing another, please do not discard the old one. There will come a time in the hobby when someone will be glad to have it to repair.
Chuck Regan
First Name: Chuck
Last Name: Regan
Post by Chuck Regan » Thu Jan 05, 2023 7:27 pm
Jeff - good advice from John and Scott. I used Loctite 660 on one of my 1926 wire wheel hubs. I also used a prick punch to raise the metal on the inside circumference of the hub - worked well.
Last Name: Hjortnaes
Post by DHort » Thu Jan 05, 2023 8:18 pm
What is a spun bearing?
Post by Mark Gregush » Thu Jan 05, 2023 9:48 pm
Spun/loose race/cup.
