WTB: Top Saddles
Scott C.
Last Name: Clements
WTB: Top Saddles
Post by Scott C. » Fri Oct 28, 2022 2:01 am
I am looking for a set of Ford marked top saddles. Does anyone have some that they would sell?
Re: WTB: Top Saddles
Post by RajoRacer » Fri Oct 28, 2022 10:16 am
For what year Scott ? 1/2" or 5/8" hole ?
RichJ
First Name: Rich
Last Name: Jesteadt
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
Post by RichJ » Sat Oct 29, 2022 12:22 am
Scott
I have a nice pair , with good used straps. they have a 1/2"hole $40.00
RonGlowczewski
Post by RonGlowczewski » Sat Oct 29, 2022 10:02 am
GIVE SCOTT CLEMENTS FIRST DIBS, but I am also looking to buy a pair of 1/2" top saddles with the arms and straps. Only interested in originals.
Post by RajoRacer » Sat Oct 29, 2022 6:31 pm
All I have left are for 5/8" irons.
havnfun
First Name: Joe
Last Name: Kowalczyk
Post by havnfun » Sat Oct 29, 2022 8:46 pm
Easy to turn 5/8 into 1/2 using an old brass spindle bushing and trim off excess. They slide right in easily, mark for hole, remove and drill slightly larger hole, once fitted, paint. To turn back into 5/8 easily remove bushing.
Regards,
Post by RajoRacer » Sat Oct 29, 2022 10:27 pm
Well, that's a handy fix Joe !
Scott C.
Last Name: Clements
Post by Scott C. » Sun Oct 30, 2022 1:30 am
Rich, I sent you an email.
Scott C.
Last Name: Clements
Post by Scott C. » Sun Oct 30, 2022 11:56 am
Still looking.
Scott C.
Last Name: Clements
Post by Scott C. » Wed Nov 30, 2022 1:20 am
Still looking for a set saddles.
Post by Original Smith » Wed Nov 30, 2022 12:38 pm
The Ford script saddles were only made with the small hole to my knowledge. There are those with as series of dots cast into them. I've never figured out what those dots mean, but there had to be some reason for it. You can't even see those dots when the leather pad is in place, but I had a good friend come over one day and wanted to know if I had an extra with the same number of dots his had, so I was able to help. I believe all the early top saddles used from 13 on up to ? had a rounded bottom. Both of my 1913's have those.
Scott C.
Last Name: Clements
Post by Scott C. » Wed Jan 11, 2023 1:45 am
Still looking for a set of saddles.
RichJ
First Name: Rich
Last Name: Jesteadt
Post by RichJ » Wed Jan 11, 2023 8:10 am
Scott
Here is another set I recently acquired . appear to be original but no markings,1/2 inch holes
RichJ
First Name: Rich
Last Name: Jesteadt
Post by RichJ » Wed Jan 11, 2023 8:21 am
RichJ
First Name: Rich
Last Name: Jesteadt
Post by RichJ » Wed Jan 11, 2023 8:32 am
E Mail sent
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Wed Jan 11, 2023 9:27 am
These are on my 23 I’m working on. One has a circle with an M in the middle and one dot. The other just has two dots.
