1915 machined hub
Mike Royster
First Name: Michael
Last Name: Royster
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout 1916 Runabout
1915 machined hub
Post by Mike Royster » Tue Feb 07, 2023 1:47 pm
I am looking to buy a machined hub for my 15 T so that I use the speedometer that came on the car, and the car has unknown wire wheels. Attached are the pictures of the hub I need. Thanks much!
Mike Royster
mr@carolina.rr.com
704-418-1177
Re: 1915 machined hub
Post by RajoRacer » Tue Feb 07, 2023 2:30 pm
Are you running ball bearings or Timkens ?
Mike Royster
First Name: Michael
Last Name: Royster
Post by Mike Royster » Tue Feb 07, 2023 6:30 pm
Unsure as I just got the car a week ago. I can pull the wheel and see. Tell me the issue please.
Thanks,
Mike
Post by RajoRacer » Tue Feb 07, 2023 7:26 pm
No issues - I'm thinking Ford produced a machined hub that took Timken bearing also - I have a couple - I'll check.
Mike Royster
First Name: Michael
Last Name: Royster
Post by Mike Royster » Tue Feb 07, 2023 8:20 pm
Thanks, I will too!
Mike Royster
First Name: Michael
Last Name: Royster
Post by Mike Royster » Wed Feb 08, 2023 7:59 am
You are correct Steve, Timken bearings! Would you be willing to part with one so I can use my speedometer?
Thank you,
Mike
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Wed Feb 08, 2023 3:20 pm
Most are probably roller bearing. All have short hub cap shoulder.All for sale $75 each
