WTB thunderbolt overhead valve cover
Jakekj
First Name: Ku21445rt
Last Name: Jensen
* REQUIRED* Type and Year of Model Ts owned: 1914 roadster
Board Member Since: 2023
Post by Jakekj » Wed Mar 08, 2023 11:30 am
Wanted thunderbolt valve cover for overhead conversion
Re: WTB thunderbolt overhead valve cover
Post by Mark Gregush » Wed Mar 08, 2023 2:03 pm
Wishing you good luck in your search, that is going to be a rare bird!
If you are going with the loss oil system, the Frontenac cover might work or like I did, original Cheverolet 1 piece rocker cover. Even out of the box, if using the Gern Thunderbolt cover and a pressure oiling system, the Chevrolet head needed to be machined around where the cover would seal and return oil system made to drain the wells.
If you have the Jern adapter plate, Olson Gaskets can make the head gasket if you need one. http://www.olsonsgaskets.com/
Also, here is a post that shows some of the work that can be done;
https://www.mtfca.com/discus/messages/29/25434.html
And even more;
https://www.bing.com/search?q=MTFCA+Jer ... cc=0&ghpl=
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Wed Mar 08, 2023 11:12 pm
On my 28 Chev 4 cylinder sprint car I had a new Jern valve cover and it sorta fit the cylinder head machined surface. I used black gasket sealer and fashioned rubberized damn seal inside the oil galley up against the boss for the original valve cover to sit on.
I had no oil leaks and was able to oil rockers often and keep the engine clean.
frontyboy
