Tt Moore torque tube hep
Mhayes2107
Last Name: Hayes
Post by Mhayes2107 » Mon May 01, 2023 3:46 am
I recently moved from a state that will not be named to the state of Texas. I am putting together a 1921 model TT truck. It came with a more transmission during the move. The movers lost my torque tube. Can anyone tell me the correct size and if they have one for sale I really don’t want to cut up a perfectly good torque tube, unless I have to to do that of course I would need the length. I sure could use some help here.
Re: Tt Moore torque tube hep
Post by Allan » Mon May 01, 2023 9:29 am
Mike, shame about the loss of your torque tube, but fitting a replacement is not a real problem, other than finding a donor tube to cut.The casting on the front of the box bolts around the tube for some 4-6'", so there is plenty of support. With the box bolted to the rear end, you can just measure the distance from the front of the box to the back of the motor. Being able to slide the tube a little in the casting helps getting the front bush up against the U joint flange. When I fitted my Moore gearbox to my buckboard, we had to juggle the pre-cut tube to get things lined up, and then clamped the front casting bolts up tight to the tube. I am presuming you have the driveshaft, but are missing the tube.
Hope this helps
Mhayes2107
Last Name: Hayes
Post by Mhayes2107 » Mon May 01, 2023 11:02 am
Thank you so much for taking the time to respond. It’s good to know that someone has been through this vetting process. I will keep track of the tips and use them if I have to cut up a torque tube I do have the driveshaft stay safe and stay away from spiders, snakes, crocodiles, well you know.
Scott Gilham
Last Name: Gilham
* REQUIRED* Type and Year of Model Ts owned: 23 TT
Post by Scott Gilham » Tue May 02, 2023 1:49 am
Try Mark Chaffin. He post's here and I know he just dismantled a few TT rear ends.
Mhayes2107
Last Name: Hayes
Post by Mhayes2107 » Tue May 02, 2023 3:40 am
Yes, I tried there. I spoke to Dave and he double checked with Mark and there are no TT torque tubes in their possession. Good suggestion though.
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Post by BUSHMIKE » Tue May 02, 2023 7:05 am
Mike,
What is the approx cut length? Is shipping one an option? I know of several in Wisconsin and Michigan. If you are not in a huge hurry, I can find you one before summer.
26modeltt
First Name: Jack
Last Name: Leonhardt
* REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
Post by 26modeltt » Tue May 02, 2023 7:45 am
Mike,
I have an uncut TT torque tube. However, the expense to ship to Texas from Wisconsin would be $$$$$ --- let me know.
Jack
BUSHMIKE
Last Name: Cushway
Post by BUSHMIKE » Tue May 02, 2023 8:34 am
If shipping remember to get a quote from Greyhound Bus. It might surprise you.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Tue May 02, 2023 10:11 am
BushMike that’s a great suggestion!! I had a turtle deck sent by bus and picked it up at the bus line station for less than $75.
Mhayes2107
Last Name: Hayes
Post by Mhayes2107 » Tue May 02, 2023 11:50 am
Hey guys, thanks for the help. The greyhound suggestion was great. I think I have access to one in Kingsbury. However, I was trying to avoid cutting a good one up extra to talk to you then Wisconsin I’m keeping your information because I may need your help in finding me one. Thanks I really appreciate the help from everybody.
