Tire Pump SOLD
aDave
First Name: David
Last Name: Dufault
Tire Pump SOLD
Post by aDave » Wed May 03, 2023 9:22 pm
Model T era single brass tube hand operated tire pump. Base is cast iron and is marked Ford. Tube is free of dings, but has obvious wear signs…must have been riding under the seat or in the turtle deck for years. It does compress air, but there is a new air hose, but no nozzle to attach to the tube valve stem – the thingamajig that screws onto the valve stem. (A rebuilding kit is available from Lang’s and others, if you plan on using it to inflate the tires). $55.00 plus shipping to your place.
aDave
First Name: David
Last Name: Dufault
Re: Tire Pump
Post by aDave » Fri May 05, 2023 8:42 am
Anyone want a tire pump? It needs a nozzle.
Jim overstreet
First Name: jim
Last Name: overstreet
* REQUIRED* Type and Year of Model Ts owned: 1925 roadster pickup project, 1916 touring project, 1929 A closed cab pickup
Re: Tire Pump
Post by Jim overstreet » Tue May 09, 2023 6:59 pm
Hello aDave, I sent you a PM. -JIm Overstreet
'Endeavor to persevere' - Lone Wattie
aDave
First Name: David
Last Name: Dufault
Re: Tire Pump
Post by aDave » Tue May 09, 2023 9:16 pm
Hi Jim,
I haven't rec'd your PM yet.
I believe the pump has been sold...I am awaiting payment....I will let you know by 5/12.
Dave
