Metzger
GOLDBARBILL
First Name: William
Last Name: Conner
* REQUIRED* Type and Year of Model Ts owned: 14 Speedster
Metzger
Post by GOLDBARBILL » Thu May 18, 2023 6:23 pm
OK. I have my windshield assembly, support rods, and found some new springs. Now I need glass. What do i need for this: channel material, glass clamps, rubber or felt for wind and rain protection? And does anybody know of a source of the actual glass in or around Seattle? Bill Conner
Re: Metzger
Post by Jerry VanOoteghem » Thu May 18, 2023 8:08 pm
This the classified section. You'll get more help by asking your questions in the forum.
https://www.mtfca.com/phpBB3/viewforum.php?f=2
RGould1910
Last Name: Gould
Re: Metzger
Post by RGould1910 » Thu May 18, 2023 8:47 pm
Im assuming you have a Mezger "Automatic" windshield used on 1909 and some 1910 Model Ts. You need brass setting channel. It's the same stuff Speedway Motors makes but the corner radii are different than those for their repro windshields. Langs has the dies and will make them up for you if you give them the dimensions and the corner radius.. The frames take 3/16"glass. Make some patterns from Masonite for the glass cutter. Good luck.
