WTB: 12 or 13 tooth pinion
popeyet
First Name: CHRIS
Last Name: MCINTYRE
* REQUIRED* Type and Year of Model Ts owned: 21 touring, 15 roadster
Board Member Since: 2023
Post by popeyet » Mon May 15, 2023 10:20 am
looking for a 12 tooth pinion to put in my roadster. Suppliers do not seem to have them in stock.
Thanks for the tips guys, I do have the recessed 40 tooth Ruckstell ring gear and I do have Rocky Mountain brakes. I With the lightness of the roadster and good running engine I think the 3.07:1 or 3:33 ratio will be what I want. I did find a 13 tooth.
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Re: 12 or 13 tooth pinion
Post by got10carz » Mon May 15, 2023 12:58 pm
Only trying to help. You know you need the recessed ring gear to use either of those pinions. Chaffins is a wealth of knowledge about this.
Post by Allan » Mon May 15, 2023 7:36 pm
In the spirit of helping, a 13 tooth pinion will give a considerably higher diff ratio, and severely compromised braking. You will need auxiliary brakes for safety.
Post by Mark Gregush » Tue May 16, 2023 1:24 am
Edit your title and put wanted in it.
