Wanted: Rocky Mountain Brake Drums
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Wed May 31, 2023 5:32 pm
I am looking for brake drums for 1909-1925 Rocky Mountain Brakes. These are the drums that fit over the stock Ford parking brake drums.
First Name: craig
Last Name: leach
Re: Wanted: Rocky Mountain Brake Drums
Post by Craig Leach » Wed May 31, 2023 11:07 pm
Hi Ed,
I picked up a set of small drum rockies, same drum as you are looking for. I found the bands were junk so I set them aside I will check out the
drums and get back to you I would be willing to sell them to recover some of the cost I incured in this puchase. Please give me till tomorrow its dark in that building.
Post by Original Smith » Thu Jun 01, 2023 11:12 am
Rock Mountain riveted the outer 12" drum to the Ford drum.
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Jun 01, 2023 5:00 pm
Hi Ed,
Yes they look to be good, very little wear. I would take $100 + shipping for the two. I also have the right side brake band, mount, lever &
hardware. ( the left side brake band had been broken & was not repaired correctly) I don't have the pedal, EZ slider or the equalizer.
Frank Thanks for being a gentleman and letting Ed have first right of refusal.
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Thu Jun 01, 2023 5:10 pm
Craig,
Thank you! I'll take them!
Sending you an email.
Ed
