Update: Bosch front plate for distributor has been found!
C_smith
Topic author - Posts: 18
- First Name: Charles
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster pickup 1926 racer
- Board Member Since: 2002
Hello MTFCA, This forum is great! Contacted yesterday regarding my request for a Bosch Front Plate for distributor. I've been in contact with a seller and arrangements made. Thank You MTFCA!
Re: Update: Bosch front plate for distributor has been found!
Charles, great! As a heads up: You can edit your original post by clicking on the pencil. After opening you can update both the subject and title, will save you from starting a bunch of new post.
