FS- 11/40 Ring and Pinion Gear Set-SOLD_PENDING PAYMENT
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Jul 25, 2023 3:56 pm
Pinion was sitting in water and is pretty pitted and the bore is scored.
The Ring gear only had surface rust and the pitting is pretty shallow- the ring gear appears to have very little wear. Ring gear would be perfect for an occasional driver if you have a good pinion. This is a Ford gear set.
$100.00 Plus $12 USPS flat rate shipping in the US. dmcgearsATyahooDOT com.
Thanks.
