FS: Taper Leaf Front Spring
Last Name: House
Post by George House » Mon Aug 14, 2023 10:43 am
Its peculiar. That’s why only $100 + the ride. Bolt holes only in main spring and top 2 springs. None in other 4. Oiler holes both ends of main spring. See 2 tabs riveted to fifth leaf…. gwhouse731(at)gmail.com
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Re: FS: Taper Leaf Front Spring
Post by Ken Buhler » Tue Aug 15, 2023 3:26 pm
George,
I have one like that with the clamp riveted. Others have the curled leaf for the clamp bolt. Does your center bolt not go through?
Work honestly
Stay true to your word
Get the job done right
Last Name: House
Post by George House » Tue Aug 15, 2023 3:44 pm
Yes. Thats why I called ‘peculiar’ and priced it accordingly. I’ve seen springs like this with bumps centered on each leaf - but not this spring. The top 2 leafs might’ve come from a spring with a bolt. I guess the center 4 might have to have a center hole drilled. Looks like it may be going to Australia.
Last Name: House
Post by George House » Sat Aug 26, 2023 8:17 am
Yep… Thanks Bill and MTFCA. It’ll be driving on the left side of the road 😔
