$80 buys all of the following new parts in their original packaging. Add $22.80 for a large flat rate box.
ITEM/QUANTITY/PART NUMBER/YEAR/CATALOG PRICE:
Owner's Plate 1 09-27 $8.00
Complete Felt Set 1 09-27 $13.00
Manifold Nut Lock Clamp 1 09-27 $5.00
Drive Shaft Bushing 1 T-2581 09-27 $9.00
Sediment Bowl Gasket 1 T-2905-B 26-27 $1.50
Pitman Arm Key 1 T-3548 09-27 $1.00
Steering Wheel Key 1 09-27 $1.00
Axel Key (2 Piece set) 1 T-2816-B 12-27 $2.00
Clevis Pins (4 EA) 3 T-2564 09-27 $3.60
Oil Dip Set (4EA) 3 T-3024 09-27 $60.00
Radius Rod Cap Springs (2EA) 3 2742 $4.20
Battery Cable Spt Bracket 1 5047 19-27 $6.00
Rear Brake Camshaft Bushing (2EA) 3 2559E 1927 $9.00
Differential Gear Key 2 T-2521 09-27 $3.00
Transmission Door Cover Bolt Set 3 T-3367 12-27 $4.80
Rear Housing Bolt Set 1 2503 $2.15
Rear Ender Bracket to Frame Bolts Set 1 T-4804 09-25 $15.00
Axel Housing Bolt Set 1 2503 B 13-27 $2.00
Lower Crankcase Cover Bolt Set 3 T-3101-BS 12-27 $9.00
Running Board Mounting Set 1 T-4813-BS 26-27 $7.00
Engine Support Bolt Set 2 T-3083-MB 09-27 $20.00
Front Fender Bracket to Frame Bolt Set 1 T-4850-MB 19-25 $14.50
KW Master Vibrator Switch Cover 1 $15.00
Manifold Glans and Copper Rings (12EA) 1 $10.00
Piston Position Sensing Kit 1 3021SK 09-27 $5.00
Pitman Arm 1 T-3547 09-27 $36.00
Valve Spring Retainer Pins (3EA) 1 T-3057 09-27 $0.10
Sediemnt Bowl Flange Washer/Lead 2 T-2905 09-25 $2.40
Front Fender Bracket Rivet Set 1 $2.25
Crankshaft Starting Pin 1 T-3040-B 20-27 $1.00
Headlight Focus Springs (2EA) 2 6591 15-27 $0.70
Starter Switch Extension 1 T-5015 19-27 $5.50
Tire Pump Check Valve Adapter 1 A-1503 $24.00
Tire Pump Hose (Original) 1 A-17052H $10.00
Brass Hood Clip Set (4EA) 1 4052B 17-27 $60.00
Terminal Blocks Rubber 2 T-5044E 23-25 $20.00
Terminal Block Wood 1 $10.00
Amp to Switch Wire 7 T-5038 19-27 $28.00
Taillamp Wire Bushing Set 1 T-5032 19-27 $5.00
Oil Pan to Block Bolt Kit 2 T-3100-BMB 11-27 $130.00
Total Cost New $565.70
Sold: Various New Model T Repair Parts
Horsehead
Topic author - Posts: 81
- Last Name: LaFalce
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster
havnfun
- First Name: Joe
- Last Name: Kowalczyk
Re: For Sale: Various New Model T Repair Parts
Email sent
Regards,
George Hand
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
John, If Joe does not want this I will Take them. George Hand gwh247@yahoo.com
