FS- Model T Front Steering Yoke with Straight Shaft and Nut- SOLD
Topic author - Posts: 57
- First Name: Ron
- Last Name: McKenzie
Model T front steering yoke with straight shaft and nut. Believed to be 09-18. New. $10 plus shipping. Phone calls preferred. 510-304-9667.
- First Name: Kevin
- Last Name: Matthiesen
Re: FS- Model T Front Steering Yoke with Straight Shaft and Nut
Note to seller. Up to 1918 the tie rod ball was a fixed part of tie rod end on the passenger side of USA left hand driver cars. The pre 1919 tie rod adjustment was on the drivers side and had a lock bolt. In 1919 Ford changed the lock bolt to have the steering ball and moved the adjustment side to the passenger side of USA car. The early version of this ball had straight shaft up to around 1921-22 when the tapered shaft ball lock bolt came out in order to make a tighter attachment. The 1919-27 tie rod end is interchangeable but the correct lock bolt must be used, look for a tapered or straight hole in tie rod end.
