Three (3) differential cases complete with spider gears and ring gear. Ring gear is 40 tooth. No pinion gears. These cases are in nice shape and all need to be cleaned up. The ring gears look to be in good condition. $25.00 per differential case plus the postage cost.
Tom five03-644-937four twoelliott@msn.com Take one or all.
Differential cases with ring gear and spider gears F S
elliott1936
Topic author - Posts: 372
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- Board Member Since: 2013
Re: Differential cases with ring gear and spider gears F S
email sent
