WTB Hershey hunting list
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sun Sep 10, 2023 4:59 pm
I will be on the hunt for these items for a 1926 Tudor at Hershey.
Driver side rear radius rod
Rear axle rebuild parts
Ruckstell axle or parts to convert axle I have
Modern driveshaft spool bearing kit
Driveshaft
Axle shafts
Hyatt axle bearings
U-joint
Sheet metal parts lower part of car
Cowl-door-quarters-rear-corners-rear panel
Subframe cross member under rear seat
Running boards
Firewall
Outer Windshield frame
Tudor safety glass
21” splitrim
New Wood spokes
Tail lights
Bosch distributor parts (front plate type)
Model T tools
King pin reamer .502
Stevens ream fixture
Drive shaft front bush facing reamer
Axle sleeve puller
Regan wheel press
And about 1000 other things :)
Bryant
Bryant
First Name: Bryant
Last Name: Shafer
Re: WTB Hershey hunting list
Post by Bryant » Mon Sep 18, 2023 5:55 pm
Tudor body rivets
Exhaust manifold
Cut out foot pedal
Front threaded wheel bearings
Wood body blocks
Nickel door handles
Maybe a good food stand 😋
Bryant
Bmodeltman
First Name: Greg
Last Name: Burgard
* REQUIRED* Type and Year of Model Ts owned: 1919 & 1914 roadsters
Post by Bmodeltman » Mon Sep 18, 2023 8:57 pm
Early forged end brake rods
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Mon Sep 18, 2023 9:04 pm
No I don’t need those thanks anyways
Bryant
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Post by FundyTides » Tue Sep 19, 2023 10:22 am
email sent
Post by Mark Gregush » Wed Sep 20, 2023 4:55 pm
Bryant
Could be he was adding to "the" wish list because he needs them?
Bmodeltman
First Name: Greg
Last Name: Burgard
Post by Bmodeltman » Wed Sep 20, 2023 9:15 pm
That's the case I misunderstood and thought it was a post for listing for what anyone was looking for. ☺️
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Tue Sep 26, 2023 6:10 am
Floating transmission shaft
Tudor passenger seat
Front and rear bumpers
All for 26 Tudor
Bryant
