u joint end of a two piece drive shaft. I hve had these for 50 yeatrs and just came across it. Not sure of value, so I will try this.
Best offer over $200 post paid. Just as I found it. I did not clean off the surface rust.
u joint end of two piece drive shaft
Topic author - Posts: 1642
- First Name: Darel
- Last Name: Leipold
Re: u joint end of two piece drive shaft
What does someone think it is worth? Any demand for such an item?
Thanks, Darel
Thanks, Darel
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Darel you "just" listed it . Some folks are still at work and have not even been able to look at this website yet. Give it a day or two perhaps?
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
sent you a message
- First Name: Darel
Have not received your message. please send again.
my last name at my last name with added s.com
- First Name: Darel
that is .org, (not .com)
- First Name: Darel
sold pending details
