For Sale: Miscellaneous Model T Parts. Shipping not included.
Heat stoves, one is nice with no pitting asking $10, the others are OK, asking $5 for them. Coil Box Sheet metal, the springs on the clips are weak, asking $8.
Water pumps. One nice one (top) asking $10. One needs total restoration and the other has a repair, asking $5 for those.
Differential Housings with ring gears. The housings look OK, the ring gears are junk. At least the bolts are salvageable. Asking $10 each.
Misc parts: Early front motor mount with a broken off bolt, $5. Used parking brake quadrant $5. Worn Control shaft blocks, $2. Pair late firewall brackets, one is broke in two, the other is OK, $2 for both. Transmission cover $5. 26-27 clutch pedal, needs straightening, $5.
Thanks for looking!
Misc. Model T Parts $10 and Under
Topic author - Posts: 481
- First Name: Rodger
- Last Name: Erickson
- * REQUIRED* Type and Year of Model Ts owned: 1920 Speedster
Re: Misc. Model T Parts $10 and Under
The "good" heat stove and the differential housings/ring gears are spoken for.
