Gas tanks fs
CTLeonard
Topic author - Posts: 1411
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
Gas tanks fs
Believe these to be 12-13 center drain tanks. Both come with straps, one has a bulb( frozen). Been on a shelf many years, one still has some good smelling gas!. 150.00 each for those plus shipping. Also pictured is a torpedo tank that has rusted through on one end. Has a center drain. Don't know if you can get these anymore, I would entertain any offer on it. It measures 12.25 x22.25. ctleonard64@gmail.com
CTLeonard
- First Name: Mike
Re: Gas tanks fs
I did forget to mention, between the two tanks one baffle is in a different location. I have them marked in pictures
Re: Gas tanks fs
Those drains look to be offset from the center. So likely 1913 to early 1920. Regardless, they look to be in pretty good condition. I don't know about your area, but around here, good ones are getting hard to find!
