FS Jno brown Brass generator.
BobP
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: Original 1911 open runabout, 1914 tr, 1916 rdts, 1921 tr, 1923 rdst, 1925 cp. 1927 pu, 1927 tr.
Post by BobP » Wed Nov 01, 2023 2:27 pm
For sale brass jnoBrown carbide generator. good used condition with some dings and imperfections. It is complete except the top part of one clamp that holds the top to the bottom. The lower part of the clamp is there. I am sure if you highly polish it there will be more imperfections that show. Look at the pictures closely. $950. No TEXTING. five07458677eight. Mn.
BobP
Last Name: Peterson
Re: FS Jno brown Brass generator.
Post by BobP » Wed Nov 01, 2023 2:28 pm
More pictures
BobP
Last Name: Peterson
Post by BobP » Wed Nov 01, 2023 2:30 pm
More pictures
BobP
Last Name: Peterson
Post by BobP » Wed Nov 01, 2023 2:31 pm
More pictures
BobP
Last Name: Peterson
Post by BobP » Fri Nov 03, 2023 7:29 am
BTTTTTTTTTTTTT I can do better on the price.
Bill Everett
First Name: Bill
Last Name: Everett
Board Member Since: 2011
Post by Bill Everett » Fri Nov 03, 2023 8:46 am
E-Mail sent.
BobP
Last Name: Peterson
Post by BobP » Fri Nov 10, 2023 12:47 pm
I was told it could be a Corcoran. I am no authority. Look closely and decide if it is the one you want. I will take $750. Let me know. Call if you are interested, 507 458 6778, Thanks, Bob.
BigAl
First Name: Alan
Last Name: Stein
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Post by BigAl » Fri Nov 10, 2023 2:36 pm
Your generator is a Corcoran. The only difference between a Corcoran and. Jno Brown is the base. A Jno Brown base is a casting with three mounting holes. If you get the base and the Jno Brown badge for the lower tank you will have a Jno Brown. These are the only differences.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Fri Nov 10, 2023 4:02 pm
I may be wrong but I believe the clamps that hold the 2 tanks together on a JB are the large wing nuts & swivel post vs the cam & clamp.
BigAl
First Name: Alan
Last Name: Stein
Post by BigAl » Fri Nov 10, 2023 5:10 pm
I know for 1911 (I have a late 1911) & 1912 the Jno Brown generator has the cam and clamp design along with the casted base and badge otherwise the generators are the same. Some Corcoran and E&J’s have the wing and post as you described. If anyone needs a picture just email me.
BobP
Last Name: Peterson
Post by BobP » Fri Dec 01, 2023 12:43 pm
btttttttttttttt
Tbird
Last Name: Bird
Post by Tbird » Fri Dec 01, 2023 3:48 pm
This is my original Corcoran generator
Before restoration and after.
IMG_1236 2.jpeg (89.68 KiB) Viewed 1878 times
Post by JTT3 » Fri Dec 01, 2023 3:59 pm
Wow I bet it took a lot to get that straightened, looks like they had it built upside down. Hehehe
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Fri Dec 01, 2023 5:32 pm
John, it’s always better to start at the bottom, easier to do that when the bottom is closer to your eyes ain’t it??
Tbird
Last Name: Bird
Post by Tbird » Fri Dec 01, 2023 8:32 pm
Wow I bet it took a lot to get that straightened, looks like they had get built upside down. Hehehe
Ha, Ha…
