1915 Holley G carburetor/sold
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Fri Dec 13, 2024 1:04 pm
New correct size float, float valve, venturi, choke spring and throttle shaft w/bushing installed. Reconditioned spray needle and spray nozzle, test run, Dec 22, 1914 patent date with brass mixture control knob and hex idle adjustment screws but steel bowl with ring around the air horn probably correct for early calendar year 1915. $250 postpaid to continental USA. Email: wlkma9@gmail.com
Last Name: House
Re: 1915 Holley G carburetor
Post by George House » Fri Dec 13, 2024 1:49 pm
beautiful work Corey ! You are an artisan …
dr1960
First Name: David
Last Name: Ruedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
Post by dr1960 » Sat Dec 14, 2024 6:57 pm
I bought one of these from Corey about 5 years ago for my '15 and it runs great! I highly recommend Corey if you are looking for quality rebuilding!
David - Yukon, OK
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Tue Dec 17, 2024 11:21 am
Back to top.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Sun Dec 22, 2024 3:53 pm
Back to top.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Fri Dec 27, 2024 12:17 pm
Back to top
Mountainrider
First Name: Neil
Last Name: Haywood
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Post by Mountainrider » Fri Dec 27, 2024 1:26 pm
Corey does great work. He rebuilt my G. Easy starter and runs great.
