Front pan mount
Front pan mount
Post by Dollisdad » Sat Feb 10, 2024 4:34 pm
I need the piece that lays into the front spring mount and the hand crank passes thru it. It is a casting riveted to the nose of the pan. It can be broken. Doesn’t matter what year. Also need a set of 11-12 hub caps. Nasty and tarnished please. Thanks.
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Re: Front pan mount
Post by FATMAN » Sun Feb 11, 2024 1:21 pm
Are you talking about the support that rivets to the pan, if so I have some,Bob
Re: Front pan mount
Post by Dollisdad » Mon Feb 12, 2024 12:36 am
This is what I’m looking for.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Re: Front pan mount
Post by Karl Von Neumann » Mon Feb 12, 2024 6:59 am
There's 2 different styles you might want to specify
Re: Front pan mount
Post by Dollisdad » Mon Feb 12, 2024 8:39 am
In my first post, I said it doesn’t matter what year. So to be clear it makes no difference if it is for an early narrow nose pan or the latter pug nose pan. Either one will work. Thanks Tom
Re: Front pan mount
Post by TRDxB2 » Mon Feb 12, 2024 10:20 am
I sent an eMail and also a PM with Pictures
Just realized that your looking fo imperfect 11-12 hub caps. think i have 3 or 4. will check tuesday
