Late 1911-1912 Rear Axle Housings $1650 Including Free Shipping in the lower 48
Tparts
First Name: Don
Last Name: Lang
* REQUIRED* Type and Year of Model Ts owned: Multiple years
Post by Tparts » Sat Feb 03, 2024 12:14 pm
Good set of 1911-1912 rear axle housings. Needs a few rivets replaced as shown in the photos. $1650 shipping included in the lower 48 states. Lang’s 1-800-872-7871
Tparts
First Name: Don
Last Name: Lang
Re: Late 1911-1912 Rear Axle Housings $1750 Including Free Shipping in the lower 48
Post by Tparts » Tue Feb 06, 2024 8:27 pm
Reduced to $1750.00
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Wed Feb 07, 2024 11:07 am
Hello Don,
I have one of these axles that I have not opened up yet and I would like to identify the year of it. Mine has two ribs on each end. On yours, the backing plates are different. One appears to have six holes and ribs and the other is plain and has five holes. Can you give me any insight as to the difference?
Ken Buhler
Work honestly
Stay true to your word
Get the job done right
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Wed Feb 07, 2024 1:24 pm
Ken, the one on the left (second pic) is “upside down”, so the ribs should be on the bottom, which is hidden by the axle tube. Oops, I didn’t look at all the pictures…… I see what you mean!!
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Wed Feb 07, 2024 1:27 pm
If it matters, very late 1911, definitely 1912. It appears that one backing plate with ribs(note the brake shoe side) has replaced the original style like the other pictured I believe. Like an early 09/10 or 11. Perhaps a 1915 style backing plate?
Tbird
Last Name: Bird
Post by Tbird » Wed Feb 07, 2024 1:52 pm
Here’s a picture of the backing plates on my clamshell.
Tparts
First Name: Don
Last Name: Lang
Post by Tparts » Fri Feb 09, 2024 8:49 pm
One backing plate has a extra hole in it more then likely for a accessory rear axle support bracket
Tparts
First Name: Don
Last Name: Lang
Post by Tparts » Tue Feb 20, 2024 9:30 am
Bump $1650.00
