FS door hinges
Karl Von Neumann
Topic author - Posts: 891
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
FS door hinges
If your in need of hinges let me know send me a pic of what you need I may have them $35 ea and up depending on the hinge lots of T and A hinges
Tinner12
- First Name: Vernon
- Last Name: Enis
- * REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
- Board Member Since: 2011
Re: FS door hinges
I need the top and bottom hinges for a 1926 4 door sedan. I have the half that screws on the door but am missing the half that is on the door pillar. The pictures are of the top and bottom that I made. I would like the original parts Size is close to approximate. Let me know what you have. You could call me at 509-671-1382 Vern 4 3/8 is bottom, 3 is top
- Attachments
- IMG_0600.jpg (87.88 KiB) Viewed 663 times
- IMG_0599.jpg (29.63 KiB) Viewed 663 times
Tinner12
- Last Name: Enis
Re: FS door hinges
forgot to say left front door Drivers side in USA
