Phinney-Walker all brass dash clock SOLD
Layden Butler
Topic author - Posts: 1734
- First Name: Layden
- Last Name: Butler
Angle mount all brass clock for vertical wooden dash mount as on brass era Model Ts. Runs when shaken but will need cleaning and lube. Also will need a mounting bracket fabricated, bracket is hidden when clock is installed.
Last edited by Layden Butler on Sat Mar 16, 2024 12:01 am, edited 1 time in total.
- Last Name: Wrenn
Re: Phinney-Walker all brass dash clock F/S
Mounted on a Model T then it oughta run well!
buff6345
- First Name: Philip
- Last Name: Quatrale
Sent San email
Tbird
- First Name: Mike
- Last Name: Bird
Here’s what the correct mounting bracket, screw that holds it together and screw cover for the bottom hole looks like.
