SOLD: another Stromberg LF - complete with dirt
Post by Scott_Conger » Thu Mar 28, 2024 5:01 pm
Complete LF
not as good as an OF, but not $400, either
'Way better than an NH
  • complete including the float and the often-missing larger version acorn nut which no one makes
  • potmetal venturi looks fine (I can detect no chips using a strong light and peering down the throat). Don't attempt to remove or you'll destroy it for certain.
  • throttle shaft in decent shape with little wear
  • high speed knob has very firm ratchet and will not slip
  • low speed "click" spring has come loose and needs to be re-riveted to the body - it is still there, being captured by the adjustment knob
  • no obvious evidence of being "mucked with" by anyone - appears "as-is" and will need some heat to liberate some rusty screws for replacement
$95 plus shipping (5 bucks more than the last one because this one is complete to the last detail)
EMAIL ME
Don't reply here and expect a quick answer or an answer at all
