The manifold is in excellent condition, the ports look unused. The plunger spring takes more effort than first expected but it needs to cause the short burst of fuel. The green tap is preventing a new ferrule from sliding off. Have everything else per the parts list except the supply elbow and 3/8 supply line. These parts, from the plunger to your fuel line, would need to be adapted to your carburetor feed setup anyway. T I will print off the instructions .
$120 plus shipping. Prefer PayPal to friend/family but will accept a personal check. If interested email me via the Forum
FS: Imperial Manifold Primer
Topic author - Posts: 6478
- Attachments
- 193165.jpg (68.22 KiB) Viewed 1991 times
Re: FS: Imperial Manifold Primer
Instructions..............
The diagram shows several check valves for siphon and squirt -
jump....jump.... bump....
Shannon_in_Texas
- First Name: Shannon
- Last Name: Helm
Frank, shouldn't that be pump....pump....bump (the starter)?!?
pump..pump..pump.
