26/27 Big Drum Ruckstell
namdc3
Topic author - Posts: 402
- First Name: Nikolaus
- Last Name: Martin
1926 1927 Ruckstell axel. I got it with other parts so I don’t know its history. It has the long shift lock and shifts like it should. I took the shift lock off and things look clean and oily inside. Comes with two wooden wheel hubs that were very tight on the axles. Keyways look good, but one side had the thread tip bent. I don’t think the axle is bent but the threads were. Ford script axles and it even had Ford script keys (which I kept as souvenirs). Standard Ford ratio gears. $850 cash and pickup only in the southern Kansas City area.
namdc3
- Last Name: Martin
Re: 26/27 Big Drum Ruckstell
Sold. Thank you.
