1913 cylinder block.
Erik Barrett
Topic author - Posts: 542
- First Name: Erik
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1924 touring 1925 dump truck
Bringing a 1913 block to the Bakersfield swap meet for sale. Working on doing all the machine work at present. Will know asking price when it is ready shortly.
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
Re: 1913 cylinder block.
Erik, Just curious, Does the '13 have the single or double reinforcing web at the back under the rear main?
1912 Torpedo Roadster
Erik Barrett
- First Name: Erik
Gene, I will have to look. I can’t see under it right now as it is on the cylinder boring machine. If it helps this was cast on 7/03/13 and built on 7/10/13.
- Last Name: Tannehill
- Board Member Since: 2002
It should have the two ribs with those dates
