Fs ruckstell parts pile
Karl Von Neumann
Topic author - Posts: 771
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Ruckstell parts just about a whole diff here the housing would need work need a tube. The guts are decent used the sliding clutch shows wear as well as the stock side of the carrier. Bearing needs replacing $800 plus the ride from pleasant prairie wisconsin or local pickup.
Would consider trading for 1913 parts building a speedster going to need alot of smalls and specific stuff
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Re: Fs ruckstell parts pile
Hello Karl,
A Ruckstell needs to be precise and tight. It can be very costly to build a dependable one. I have five Ruckstell gear carriages apart on my bench and I am using micrometers and calipers to determine the precise measurements of each part so that I will know which parts to replace. Looking at what you are showing is like looking at a car going by in a parade. If you could provide measurements of the critical wear areas, it would be helpful.
Work honestly
Stay true to your word
Get the job done right
Karl Von Neumann
- First Name: Karl
Ken if I had bule print or measurement I would be able to post that's info I also have several ruckstells I'm going thru as well
Karl Von Neumann
- First Name: Karl
Karl Von Neumann
- First Name: Karl
Karl Von Neumann
- First Name: Karl
Karl Von Neumann
- First Name: Karl
Karl Von Neumann
- First Name: Karl
RGould1910
- Last Name: Gould
Just a suggestion Karl. You dont need blueprints or original specs. If you have a dial caliper, measure the wear aeas and report. Yiou'll have better responses I think.
