FS Tools Bearings Carbs
Topic author - Posts: 1631
- First Name: Kim
- Last Name: Dobbins
- First Name: Kim
Re: FS Tools Bearings Carbs
Put my name on the Blackhawk 4422, please Kim.
- First Name: Kim
1krw pinion gear puller, clutch drum puller, 4 bearings, 4 in one wrench, trans gear puller and mossberg u joint wrench are sold.
- Last Name: Straw
- * REQUIRED* Type and Year of Model Ts owned: 1915 and lots of parts
Kim- I need the 161 wire wheel wrench- thanks
- First Name: Kim
T 161 and Blackhawk 4422 are sold.
- Last Name: Tannehill
Kim I’ll take the other Tranny gear puller & 3Z 646
- First Name: Nathan
- Last Name: Warburton
Are the carbs rebuilt? Or just cleaned up?
- First Name: Kim
Both carbs are sold.
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
- Board Member Since: 2014
Email sent
- First Name: Kenneth
- Last Name: LeBlanc
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
E mail sent
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Is the APCO perch remover still available ?
Scott
Scott
- First Name: Kim
Perch puller is sold
