Floating rear axle hub kit F/S
Topic author - Posts: 1691
- First Name: Layden
- Last Name: Butler
This new never installed kit replaces the Hyatt outer roller rear axle bearing with a sealed large ball bearing. It also provides a modern seal on the axle shaft to stop differential lube from leaking onto the brakes. This kit does both left and right rear axles. The bearing mounts have 6 holes so are intended for wood wheels ( that includes accessory wire and disc wheels that use standard 6 bolt pattern drums). If you are using 1926-27 Ford wire wheels with 5 bolts, the bearing mounts could be re-drilled to that pattern. Asking price is $475 which includes domestic shipping. The estate's loss is your gain, see catalog prices! Only this one set so when gone there will be no other available here.
- Last Name: Butler
Re: Floating rear axle hub kit F/S
$475 including shipping!
