SOLD! various brass Holley G parts and gasket set
Topic author - Posts: 449
- First Name: Walt
- Last Name: Wise
What we have here is some left over parts from rebuilding Holley G carbs and since I have sold all the G's that I have, plus won't be buying anymore, I thought for sure that someone could use these parts: the allusive strangling tube that always seems to be robbed out of cores, plus the "set" screw that the tube is attached to that a lot of times you can destroy trying to get them out to clean inside the jet area. also a brass Pat. Pend. top of the carb, along with the clamping nut for the spray needle - 4 parts that none of the vendors sell new, and lastly a new/never used complete G gasket set, and a couple of additional gaskets. Asking $25 plus $10 shipping to any of the lower 48 contiguous states only. Paypal preferred, using the Family and Friends option or a check will work too. If interested, I will provide needed info for payment. Thanks for looking!!! Walt Wise
- First Name: Ron
- Last Name: Wenzel
- * REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Re: For Sale: various brass Holley G parts and gasket set
Hey, Walt,
Sending you an email, sir.
Regards,
Ron in HSV
Regards,
Ron in HSV
- First Name: Walt
- Last Name: Wise
Re: SOLD! various brass Holley G parts and gasket set
Thanks MTFCA!!!
Walt Wise
Walt Wise
