Use this as a lesson how to terminate an ad WITHOUT BUMPING EVERYONE ELSE'S STUFF DOWN THE LIST.
Junk carb - not reasonably a rebuild candidate...it is a donor carb
no float cover nut
no float
no float valve needle
no choke wire securing screw
modified mixture needle
pictures are the best description
despite the obvious problems, there remain a number of parts which are simply unobtainable anywhere at any price, if you happen to need them for your project
$60 plus postage
EMAIL ME THROUGH THE FORUM
DO NOT USE THE PM SYSTEM
I DO NOT WATCH ADS CLOSE ENOUGH TO RESPOND IN A TIMELY BASIS
Thank you
Stromberg LF for parts - not for restoration -SOLD
Topic author - Posts: 6707
