Winfield S & SR carburetor parts **NEW**
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 18, 2020 9:37 pm
Brand new Winfield model S & SR carburetor choke horns, V band clamps, and choke brackets now available. All components are near exact reproductions of the original designs and will interchange with original components. Current available size is AA-B only. Other sizes to be available depending upon demand.
Choke horns are machined from solid aluminum and are ready to install. Completely assembled with new stainless steel choke butterfly and brass pivot shaft. $250 ea.
V band clamps are machined from solid stainless steel and are ready to install, complete with stainless steel hardware. $90 ea.
Choke brackets are stamped from stainless steel and are ready to install, complete with stainless steel mounting screws and clamp screw/nut. $40 ea.
First Name: Henry
Last Name: Lee
Re: Winfield S & SR carburetor parts **NEW**
Post by Henry K. Lee » Fri Sep 18, 2020 9:42 pm
Very nice work Kevin!
Hank
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 18, 2020 9:42 pm
Contact info...
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Sep 27, 2020 2:34 pm
Bump......
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Oct 16, 2020 10:30 pm
Been working on a new float bowl... pics coming soon👍
elliott1936
Last Name: Elliott
Post by elliott1936 » Sat Oct 17, 2020 12:16 pm
Kevin:
I would like to purchase a clamp for the air horn. Tom Elliott 503-644-9374
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Oct 19, 2020 11:50 pm
Thank you Tom! It on its way 👍
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Oct 30, 2020 8:21 pm
Bump......
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Dec 01, 2020 1:43 am
Have been continuing toward my goal of building complete S-B downdrafts from scratch. So far the choke horn, V band clamp, and float bowl are done. The float bowl cover and float ball for both S and SR carbs are next.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Fri Dec 04, 2020 8:11 am
Wow!!!!!!!
Here is my old beater
John bevardos
Last Name: bevardos
* REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Post by John bevardos » Fri Dec 04, 2020 12:50 pm
How well do these perform . I have a couple at home and haven't tried them .......yet .
John
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Dec 04, 2020 10:31 pm
I’m a bit biased... so I will hold my comments 😉. But I will say that rather than arguing over which factory produced carburetor worked best, the Winfield S/SR and similar designed carbs were normal equipment at Indy throughout the 30’s👍
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Jan 28, 2021 10:16 pm
I’m still workin toward complete carbs, and so have straight and elbow choke horns, V band clamps, choke brackets, and now fuel inlet blocks in stock. Will also have S and SR float balls, and modern needle and seat float bowl covers available soon...
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Fri Jan 29, 2021 12:07 am
When you get it PLEASE let us know, I have a B sized BB body that is perfect but for the manifold flange on top that has a radial crack 60% around it...it makes me sick, as I want so bad to rin this carb, but I know, lest I build a brace to hold it up, it will fail...
What you are doing is a true GIFT to the hobby... I just wanted to say that... along with our heartfelt thanks!!!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Aug 27, 2021 11:56 pm
Continuing to make progress, now have new float bowl covers complete with ball detents, new float levers, and Viton tipped float needles
And here’s a pic of progress so far, still have some cosmetic work to do to the exterior of the throttle barrel, but otherwise is internally finished
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Aug 25, 2024 6:33 pm
Guess it’s been a while since the last bump. Have been continually adding new parts and accessories for Model S and SR series carbs. All interchangeable with original components, from gaskets to throttle barrels.
V band clamps in all sizes
Compensator and accelerator pump tools
Brass floats
