Floating rear axle safety hub kit SOLD
Layden Butler
Topic author - Posts: 1734
- First Name: Layden
- Last Name: Butler
This new never installed kit replaces the Hyatt outer roller rear axle bearing with a sealed large ball bearing. It also provides a modern seal on the axle shaft to stop differential lube from leaking onto the brakes. This kit does both left and right rear axles. The bearing mounts have 6 holes so are intended for wood wheels ( that includes accessory wire and disc wheels that use standard 6 bolt pattern drums). If you are using 1926-27 Ford wire wheels with 5 bolts, the bearing mounts could be re-drilled to that pattern. Only this one set so when gone there will be no other available here.
