Stromberg RF idle jet
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Mon Oct 14, 2024 8:51 pm
Is anyone reproducing the idle jet for a Stromberg RF carburetor?
paulgriesse
First Name: paul
Last Name: griesse
* REQUIRED* Type and Year of Model Ts owned: 1924 touring 1912 touring
Board Member Since: 2003
Re: Stromberg RF idle jet
Post by paulgriesse » Tue Oct 15, 2024 11:18 am
Means Garage------3783 s 21st rd dunnegan, mo. ozarkcreekrats2gmail.com They were at Hershey this year and make/ sell all Stromburg O F parts. ( He says better than Stan howells stuff....) Paul
Etudes10
First Name: Greg
Last Name: Cosner
* REQUIRED* Type and Year of Model Ts owned: 1915 touring, 23 coupe, 26 speedster, 25 tudor, 25 TT
Post by Etudes10 » Tue Oct 15, 2024 1:13 pm
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Tue Oct 15, 2024 2:35 pm
The OF and RF are two distinctly different carbs. The RF was Stromberg's improved version of the OF and looked very little like an OF. It's all aluminum and has a float system similar to a Model A carb. Unfortunately the brass idle jet seems to weld itself to the aluminum body and very few are removable without somewhat destroying the jet. I've done maybe 8-10 of these carbs and they run every bit as good or even better compared to the OF and without and "runny-nose syndrome" of the OF. Stan Howe wouldn't touch these unless you could prove that the idle jet could be removed. I found a NOS Stromberg RF at Hershey and the jet came out easily so I have a perfect one for reproduction.
Post by Allan » Tue Oct 15, 2024 7:10 pm
Bruce, can you please post a photo of your RF. I'd like to know what to be looking for.
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Tue Oct 15, 2024 7:29 pm
Here is a pic of the Stromberg RF
Post by Allan » Sat Oct 19, 2024 11:08 pm
Thanks Bruce. It is quite distinct. I'll be keeping an eye out for one.
