TT Closed Cab door check straps
Post by RajoRacer » Sun Apr 07, 2024 11:48 am
I've had several closed cab rigs in the shop for odds & ends repairs and not one had door check straps so I had some done up using the remnants of one using similar webbing material & the length I kinda judged by the door position. These fit original & repro footman loops. I have a limited number of pairs and am asking $25.00 for a pair including a small flat-rate Priority Mail. Drop me a note through the Forum, please if interested.
Re: TT Closed Cab door check straps
Post by RajoRacer » Mon Apr 08, 2024 1:06 pm
BTT - all you closed cab folks have straps ????????
Post by RajoRacer » Sat May 04, 2024 2:35 pm
BTT - I have several sets available.
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Post by BUSHMIKE » Sat May 04, 2024 3:32 pm
Ill take a set. Here is a pic of what I believe to be an original strap. The hardware is original and the leather copied off the broken original. Yours are a very nice easy solution.
Post by RajoRacer » Sat May 04, 2024 5:30 pm
I highly suspect Ford would go to the expense to produce such a complicated leather arrangement - I've not seen any part numbers or illustrations for such a beast !
Post by RajoRacer » Fri Nov 08, 2024 8:34 pm
Back up again - 6 months later - still have multiple sets available.
KenHaverhill
First Name: Kenneth
Last Name: LeBlanc
* REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
Post by KenHaverhill » Sun Nov 10, 2024 11:30 am
I will take a set should I pm you ?
