Original Brass Schrader tire valve covers / dust caps
KiwiFordGuy
First Name: Alex
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1925
Post by KiwiFordGuy » Fri Nov 08, 2024 5:33 am
A very nice set of original Schrader brass era valve covers as pictured. $220 USD including freight.
PayPal friends and family.
Please private message if interested
KiwiFordGuy
First Name: Alex
Last Name: Brown
Re: Original Brass Schrader tire valve covers / dust caps
Post by KiwiFordGuy » Fri Nov 08, 2024 5:41 am
Photos as follow
Tbird
Last Name: Bird
Post by Tbird » Fri Nov 08, 2024 7:39 am
I believe those rim nuts fit the 725 valve stems.
Bill Everett
First Name: Bill
Last Name: Everett
Board Member Since: 2011
Post by Bill Everett » Fri Nov 08, 2024 10:06 am
Mike, in your opinion, do you feel that the rim nuts pictured are not a match for the valver covers shown?
BigAl
First Name: Alan
Last Name: Stein
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Post by BigAl » Fri Nov 08, 2024 11:36 am
My basket case late 1911 Touring did have a couple of these rim nut/washers on a couple of wheels. I understand between 1911 and when I purchased the car in 1980 a lot of things could have been changed. But my research has lead me to believe these are correct. The rim nuts just need a leather washer on the rim side. These original rim nuts/washers with the markings are very hard to find. Once again only my opinion.
Tbird
Last Name: Bird
Post by Tbird » Fri Nov 08, 2024 5:52 pm
Hi Bill, so those valve covers will fit with those rim nuts, however those rim nuts fit the 725 valve stem size and so you will have to do a lot of turning the cover to get it off the stem. The original round rim nuts had a small shoulder that the covers threaded onto. The rim nut have pictured below fit the smaller diameter 777 stems. They also do not have any markings on them.
KiwiFordGuy
First Name: Alex
Last Name: Brown
Post by KiwiFordGuy » Fri Nov 08, 2024 7:29 pm
Further images
KiwiFordGuy
First Name: Alex
Last Name: Brown
Post by KiwiFordGuy » Wed Nov 13, 2024 9:15 pm
To anyone interested, send me a sensible offer via private message.
