For sale: Wire wheel in like new condition $150 plus shipping
wire wheel
Topic author - Posts: 1755
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
- Last Name: Golden
Re: wire wheel
The hub cap hole should be measured, as it looks larger.
That looks like a rare 1928 Model AR wire wheel.
That is something I learned the hard way!
The one on the left is a 1928 Model AR wheel.
- First Name: Melba
- Last Name: Nolan
Re: wire wheel
ok is that how you tell a T from an A by the size of the center hole?
Re: wire wheel
The were two styles of 21" Model A wire wheels. Early 1928 were the "AR" style and then for 1928 & 1928 the ribbed styleMelba Nolan wrote: ↑Fri Nov 29, 2024 11:06 amok is that how you tell a T from an A by the size of the center hole?
Re: wire wheel
Hub cap differences too -
- Last Name: Golden
Re: wire wheel
That Model A 28 -29 hubcap may be what I have and didn't want.
The hole is just large enough for a 1926 hub cap to drop right through it.
- First Name: Melba
- Last Name: Nolan
Re: wire wheel
When I can get in the trailer again I will check the size of the hole. It looks like you said.
