There is currently on Ebay a small drum wire wheel hub misidentified as for '26-'27. It ain't cheap, but try and find another one!
https://www.ebay.com/itm/156591043174?_ ... R4DZ07j9ZA
Small Drum Wire Wheel Hub on Ebay
old_charley
Topic author - Posts: 226
- First Name: Bryan
- Last Name: Ostergren
- * REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
Re: Small Drum Wire Wheel Hub on Ebay
No view of the inside bolts. Cant tell if its modified or genuine.
- Last Name: Hatch
Here is a link to the only real small drum wire wheel hubs I have seen in 50 years of Model Ting.
https://mtfca.com/phpBB3/viewtopic.php?t=33354
Dan's link to some real ones shows a difference in the hub on the outer end. The one on Ebay has been machined like the standard 26-7 wire wheel hubs so the factory puller will work. It is nothing like the pair in Dan's link.
- Last Name: Hatch
Those on Tbay look like homemade. Can’t tell from pictures, but I have seen a lot of that kind. I have even made a few myself.
