Complete U&J carburetor/manifold
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Sat Dec 28, 2024 12:07 am
Rebuilt, and engine tested U&J carb with the correct manifold. This is the ultimate set-up for any T, easy to adjust, and provides the most power over all other aftermarket carbs (check out the late Stan Howe's posts). It has had the standard milling operation to accept a Holley G bowl and this one has the heavy brass bowl. You will need to fabricate a throttle rod. Asking $850.00 including shipping to cont. USA and Canada.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Re: Complete U&J carburetor/manifold
Post by rickd » Sat Dec 28, 2024 6:39 am
I sent an email to you Bruce.
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Sat Dec 28, 2024 1:01 pm
The U&J is spoken for. Thanks MTFCA.
