Clip on American Bosch distributor. Has been cleaned, inspected, bead blasted, Painted with high heat clear ceramic paint, points modified so
they can be adjusted to spec with more adjustment left. Shafts are good & tight, lubed & bench tested. Has the cam gear, spacer, nut & pin.
Price reduced from $275 to $250 + shipping from earlier post.
Centrifugal W/ arm.
F/S American Bosch Distributor
Topic author - Posts: 2036
- First Name: craig
- Last Name: leach
