Ignition Key #63 King Lock
Topic author - Posts: 54
- First Name: Stuart
- Last Name: Tomlinson
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1913 Huckster, 1924 Touring, 1927 Tudor
WTB. Model T Ford Ignition Key #63 produced by King Lock Company. The manufacturing insignia on the key is a small kings crown with the letter “K” inside of it. The insignia is just under the Ford Script on the front of the key.
- First Name: Kent
- Last Name: Palazzo
Re: Ignition Key #63 King Lock
I have a #63 key, & switch assembly. The key is worn on the face side, #63 is readable. The ammeter is broken in the assembly. The key switch and light switch both work. I can't tell if there's a letter "K" on the face due to being worn almost smooth. I don't know if this is any help, you can let me know. Oh it's out of a 26 Tudor.
Hi Kent,
Thanks for your note. I will send you an email via the forum.
Stu
Stu
