NEW Electric Brass STOP Light/Tail Lamp
Stephen1915
First Name: Stephen
Last Name: Noll
* REQUIRED* Type and Year of Model Ts owned: 1916 Coupelet & 1911 Torpedo
Post by Stephen1915 » Mon Mar 10, 2025 1:51 pm
This is a beautiful new heavy brass stop light/tail light. There is a steel diffuser plate with stop cut into it. If you would like to use this as a running light or a solid red tail light, the diffuser can be removed. The tail light lens is a standard oil lamp lens so if it breaks it is easily replaced. Single contact bulb base can easily be converted to dual contact for a Running and Stop light.
$120 plus shipping
314-287-1901
Stephen1915
First Name: Stephen
Last Name: Noll
Re: NEW Electric Brass STOP Light/Tail Lamp
Post by Stephen1915 » Thu Mar 13, 2025 4:10 pm
Spoken for.
