F/S: Hyatt Roller Bearings for Rear End - SOLD
Topic author - Posts: 124
- First Name: Jonathan
- Last Name: Bodine
- * REQUIRED* Type and Year of Model Ts owned: 1914 roadster
For Sale are three Hyatt Roller Bearings for the Rear End. They look good to me and appear to be tight. $45.00 each plus shipping.
Adjusting price to $45.00 each. They need to be in a Model T differential somewhere.
These are really nice bearings. Like I said originally, really tight!
R/S,
Jonathan Bodine
jethro10101@aol.com
1 406 498 3946
R/S,
Jonathan Bodine
jethro10101@aol.com
1 406 498 3946
- Last Name: Bodine
Re: F/S: Hyatt Roller Bearings for Rear End - used
Back to the top, please.
- Last Name: Bodine
Adjusting price to 45.00 each. They need to be in a Model T differential somewhere.
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Jonathan, What does each roller measure at each end with a micrometer? There is a number that will make them junk and you need to present that. Is there galled metal in the cracks? "Looks good" and "should be okay" doesn't cut it.
Ken
Ken
Work honestly
Stay true to your word
Get the job done right
Also if you hold one on each end can you twist it a little, a lot or not at all. if you can twist it, there isn't much need to measure each roller
- Last Name: Bodine
Back to the top
- Last Name: Bodine
Price adjustment: $45.00 each plus shipping. All three would probably fit into a medium flat rate box.
What an opportunity to get good original parts.
- Last Name: Bodine
Re: F/S: Hyatt Roller Bearings for Rear End - SOLD
SOLD
More available soon...Stay tuned.
