Bosch manual advance distributor ( spoken for ...thanks MTFCA)
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sat Apr 12, 2025 8:45 pm
Bosch distributor with manual advance ... advance works smoothly and distributor housing is in good condition ... will need cleaning and lubrication ... cap and rotor are good , points will need replacement or filing to clean contact surfaces ... drive gear is good ... price is $200 + $19.15 postage in lower 48 states , actual postage outside this area or INTERNATIONAL ...contact thru MTFCA site ...Gene French
Gene_French
First Name: Gene
Last Name: French
Re: Bosch manual advance distributor
Post by Gene_French » Fri Apr 18, 2025 8:45 am
to the top ...thanks MTFCA
JLBLJB@aol.com
Last Name: Berger
* REQUIRED* Type and Year of Model Ts owned: 1926
Post by JLBLJB@aol.com » Fri Apr 18, 2025 9:52 am
Good morning Mr. French I would like to purchase your Bosch distributor. do you take Pay Pal. you can respond to me at JLBLJB@AOL.COM Thanks Jerry Berger
