LOOKING for WHEEL HARDWARE FOR WOODEN WHEELS METAL STEM
avent40
First Name: Anthony
Last Name: Ventrice
* REQUIRED* Type and Year of Model Ts owned: 1922 Ford model t touring
Post by avent40 » Wed Apr 16, 2025 10:57 am
Please can you help me locate wheel hardware for 4 wheels including dustcovers for metal stem tubes Thanks so much. Tony
Re: LOOKING for WHEEL HARDWARE FOR WOODEN WHEELS METAL STEM
Post by Allan » Wed Apr 16, 2025 9:35 pm
If you are looking for rim bolts, loose lugs, nuts to hold the rims on the wheels, Langs have them all. Metal stem dust covers come in two sizes, so you need to specify which you are looking for.
Post by TRDxB2 » Thu Apr 17, 2025 12:37 am
As Alan indicated you need to be more specific as to what you need.
There are many styles of rim lugs which are designed to mate to a comparable rim & felloe. I have a variety of many different lugs. I have a supply of new hub bolts & some nuts plus. If you don't have tubes yet, then you should wait till you have them for the proper valve caps
