Neat oil level gauge with a cork float that pushes up a wire to see your oil level. I’ve never used it, but it should work as designed.
Asking $85 shipped CONUS.
Thanks,
Nick
PSUNicholas@yahoo.com
551 427 1593
APCO Accessory oil level gauge
Re: APCO Accessory oil level gauge
These work well. The petcock goes in where the plug is fitted. There is a little glass bead fixed on the wire at the top to be a more visible indicator.
MNToys
Topic author - Posts: 143
- First Name: Nick
- Last Name: Rein
bump to the top
MNToys
- First Name: Nick
- Last Name: Rein
Bump to the top
